Помогите пожалуйста схемой ABS
Автор solovei84, 24 мая 2013, 03:15:26
solovei84Автор темы
Пожалуйста помогите схемой соединений блоков ABS . Поблема в том что  горит на панели ABS при чтении ошибок ругается на насос и ошибка не снимается . По факту на насосе нет питания !
Автос - C 180 99г.в  WDB2020181A794357
Заранее всем спасибо !
solovei84, если до вечера никто не даст схем, то вышлю
тока мыло в личку скинь
A1 Instrument cluster 52 A
A1e17 ABS MIL 54 A
A1e39 EA [EFP] warning lamp 55 A
A1e6 Brake pad wear indicator lamp 53 A
A1e7 Brake fluid and parking brake warning lamp 54 A
A7/3 Traction systems hydraulic unit 3 L
A7/3 Traction systems hydraulic unit 14 L
A7/3m1 High pressure and return pump 5 L
A7/3m1 High pressure and return pump 15 L
A7/3y20 Rear axle solenoid valve (hold) 2 J
A7/3y20 Rear axle solenoid valve (hold) 14 K
A7/3y21 Rear axle solenoid valve (release) 3 J
A7/3y21 Rear axle solenoid valve (release) 13 K
A7/3y6 Left front axle solenoid valve (hold) 2 K
A7/3y6 Left front axle solenoid valve (hold) 14 J
A7/3y7 Left front axle solenoid valve (release) 3 K
A7/3y7 Left front axle solenoid valve (release) 14 K
A7/3y8 Right front axle solenoid valve (hold) 2 K
A7/3y8 Right front axle solenoid valve (hold) 13 J
A7/3y9 Right front axle solenoid valve (release) 3 K
A7/3y9 Right front axle solenoid valve (release) 13 K
G1 Battery 32 L
K40/2 Driver-side fuse and relay module 7 L
K40/2 Driver-side fuse and relay module 18 L
K40/2k4 High pressure/return pump relay 8 L
K40/2k4 High pressure/return pump relay 18 L
K40/4 Front passenger-side fuse and relay mod ule 38 L
K40/4f2 Fuse, traction system 40 L
K40/4k1 Polarity protection relay 36 L
L6 Rear axle VSS [GES] sensor 28 L
L6/1 Left front wheel speed sensor 23 L
L6/2 Right front wheel speed sensor 26 L
N47-7 ABS control module 3 A
N47-7 ABS control module 9 A
N47-7 ABS control module 13 A
N47-7 ABS control module 20 A
N47-7 ABS control module 28 A
N47-7 ABS control module 36 A
N47-7 ABS control module 44 A
N47-7 ABS control module 50 A
N73 DI control module 30 L
S10/1 Left front brake pad contact sensor 24 L
S10/2 Right front brake pad contact sensor 26 L
S12 Parking brake indicator switch 49 L
S9/1 Stop lamp switch (4-pin) 42 L
U12 Valid for left-hand steering 23 D
U12 Valid for left-hand steering 36 G
U12 Valid for left-hand steering 49 J
U13 Valid for right-hand steering 29 D
U13 Valid for right-hand steering 30 D
U13 Valid for right-hand steering 35 G
U13 Valid for right-hand steering 48 J
U147 Valid for Bosch system 1 A
U148 Valid for Teves system 11 A
U152 Valid for model 202 1 B
U152 Valid for model 202 11 B
U152 Valid for model 202 33 J
U152 Valid for model 202 42 F
U153 Valid for model 208 11 B
U153 Valid for model 208 32 J
U153 Valid for model 208 44 F
W1 Main ground (behind instrument cluster) 29 H
W16/3 Ground (output ground - component compartment - left) 5 E
W16/3 Ground (output ground - component compartment - left) 16 E
W16/3 Ground (output ground - component compartment - left) 29 E
W16/3 Ground (output ground - component compartment - left) 35 E
W16/3 Ground (output ground - component compartment - left) 48 H
W16/4 Ground (output ground - component compartment - right) 35 E
W29/2 Ground (right A-pillar) 22 E
W29/2 Ground (right A-pillar) 49 H
X11/4 Data link connector 38 E
X12/3 Circuit 30 connector block 21 E
X18 Interior and taillamp harness connector 43 G
X20 Stop lamp switch intermediate connector (2-pin) 42 K
X26/23 Engine compartment/cockpit connector 30 E
X4 Terminal block (circuit 30, left footwell) 10 L
X4 Terminal block (circuit 30, left footwell) 20 L
X43/3 REST/CL [MRA/ZV] connector, circuit 30Z 32 E
X47 Rear axle VSS [GES] sensor harness connector (2-pin) (right footwell) 27 E
X47 Rear axle VSS [GES] sensor harness connector (2-pin) (right footwell) 43 E
X62/11 ABS rear axle VSS [GES] sensor (2-pin) 27 H
X62/6 Right front axle multiple circuit junction connector, in component 25 H
compartment
X62/7 Left front axle multiple circuit junction connector, in component 23 H
compartment
Z37/2 CAN engine bus (low) connector sleeve 51 H
Z37/3 CAN engine bus (high) connector sleeve 52 H
Что за ошибка-то?
skyloord
номер ошибки  напиши?
solovei84Автор темы
skyloord
solovei84Автор темы
#6
Очень похожие симптомы !!! при заводке не горит, загорается только в движении . Завтра буду разбираться .
skyloord
попробуй релешку скребкой замкнуть.  там тоже написанно какую и как при включенном зажигании
отправил схему
схему нужную смотри в зависимости от производителя гидроблока
solovei84Автор темы
Проблема решена .
Дело было в трёх загнутых ножках на самом контроллере ABS.
Всем огромное спасибо за помощь !!!
skyloord
Цитата: solovei84 от 26 мая 2013, 20:23:01
Проблема решена .
еще одной проблемой меньше)
