Цепь ГРМ
Автор Игорь1982, 27 февраля 2012, 16:09:34
Игорь1982Автор темы
Пришли запчасти
1.https://w202club.su/radikal/000/F/s57.radikal.ru/i156/1203/ab/0430894a6e6f.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s57/i156/1203/ab/0430894a6e6f.jpg" alt="https://w202club.su/radikal/s57/i156/1203/ab/0430894a6e6f.jpg" />
2.https://w202club.su/radikal/000/F/s59.radikal.ru/i163/1203/8b/a03e78428221.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s59/i163/1203/8b/a03e78428221.jpg" alt="https://w202club.su/radikal/s59/i163/1203/8b/a03e78428221.jpg" />
3. Заказ снят
4. https://w202club.su/radikal/000/F/s019.radikal.ru/i600/1203/5e/8c8271083341.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s019/i600/1203/5e/8c8271083341.jpg" alt="https://w202club.su/radikal/s019/i600/1203/5e/8c8271083341.jpg" />
5.https://w202club.su/radikal/000/F/s54.radikal.ru/i146/1203/2c/4dd9ebaaf467.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s54/i146/1203/2c/4dd9ebaaf467.jpg" alt="https://w202club.su/radikal/s54/i146/1203/2c/4dd9ebaaf467.jpg" />
6. https://w202club.su/radikal/000/F/s12.radikal.ru/i185/1203/64/10c916061ba8.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s12/i185/1203/64/10c916061ba8.jpg" alt="https://w202club.su/radikal/s12/i185/1203/64/10c916061ba8.jpg" />
7.https://w202club.su/radikal/000/F/s019.radikal.ru/i621/1203/41/4b3854be6b8e.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s019/i621/1203/41/4b3854be6b8e.jpg" alt="https://w202club.su/radikal/s019/i621/1203/41/4b3854be6b8e.jpg" />
8. https://w202club.su/radikal/000/F/s019.radikal.ru/i639/1203/e2/dcdea4630b2f.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s019/i639/1203/e2/dcdea4630b2f.jpg" alt="https://w202club.su/radikal/s019/i639/1203/e2/dcdea4630b2f.jpg" />
9.https://w202club.su/radikal/000/F/s44.radikal.ru/i105/1203/ca/93591424bb16.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s44/i105/1203/ca/93591424bb16.jpg" alt="https://w202club.su/radikal/s44/i105/1203/ca/93591424bb16.jpg" />
10. https://w202club.su/radikal/000/F/s019.radikal.ru/i608/1203/e2/5e8fcc56dfc6.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s019/i608/1203/e2/5e8fcc56dfc6.jpg" alt="https://w202club.su/radikal/s019/i608/1203/e2/5e8fcc56dfc6.jpg" />
11. https://w202club.su/radikal/000/F/s41.radikal.ru/i094/1203/6b/52d0899fd7db.jpg" rel="nofollow" target="_blank">https://w202club.su/radikal/s41/i094/1203/6b/52d0899fd7db.jpg" alt="https://w202club.su/radikal/s41/i094/1203/6b/52d0899fd7db.jpg" />
Кто что предложит по пункту №3. НЕ очень хочется с разобранным движком месяц деталь ждать.
Отредактировано igor1982 (2012-03-19 16:45:07)
Alex_cat87
Подскажите ГДЕ МЕТКИ???? как выставлять?
ПО МОЕМУ МОТОРУ?
где найти фиксирующий инструмент на распредвалы?
Отредактировано Alex_cat87 (2012-04-11 21:41:00)
Игорь1982Автор темы
Я так понимаю у нас моторы одинаковые? Можно взять сверла по размеру и вставить в отверстия, как показано на рис. 1. (Я туда гвозди вставлял, но народ не одобрил))   ).
Asus007
подбери нужные сверла чтоб прям впритык и все будет в елочку!
Бог создал людей, Мерседес - лидеров.
bulbul
а зачем тебе прокладка головки блока? снимать голову собрался?, тогда болты новые нужны:) ну и маслосъемные поменять конечно стоит:) раз все в руках будет:)
TCooper
Alex_cat87
Метка выставляется на шкиве КВ, +20гр., если не ошибаюсь. Ориентацию звезд относительно верхней направляющей надо пометить маркером. В качестве фиксирующего инструмента можно использовать большой рожковый ключ на 32.
Pilot88052
Некоторое время назад мы в какой-то теме обсуждали вопросы замены цепи и выставления по меткам валов. Там я в силу знаний Инглиша даже немного перевел рекомендованную последовательность операций при замене цепи. И там же где-то писал про допуски. И в который раз напомню два основополагающих цепных правила по 111 мотору:
1. КОЛЕНВАЛ СТАВИМ СТРОГО НА 20 ГРАДУСОВ ПОСЛЕ ВМТ 1 ЦИЛИНДРА!!!
2. НАТЯЖИТЕЛЬ ЗАРЯЖАЕМ СТРОГО НА БЛОКЕ ЦИЛИНДРОВ (и ни в коем разе не в руках! в противном случае ломает выпускной распредавал от перенатяжения цепи)!!!
Писал капсом умышленно.
Мне уже несколько раз даже звонили едва знакомые люди с вопросами, че, мол мотор глухо и натужно крутится, воет, как японский автомат и глохнет на холостом... Уже пару моторов только по телефону спас...
Отредактировано Pilot88052 (2012-04-13 12:25:14)
С уважением, Алексей
Alex_cat87
Коленвал на 20 не ставится, чуть есть отклонение, может потому что звездочки оставил старые. И еще,мотор все равно шумно работает
Отредактировано Alex_cat87 (2012-04-15 17:21:50)
сам делал или сервис? колено при новой цепи и старых звездах на место не встанет будет расхождение градусов в пять. а по поводу шумности ты ж его не капиталил а всего лишь цепь поменял а шумов там и иных достаточно
Alex_cat87
менял хороший приятель с большим стажем, значит все звёзды под замену? ну и кончечно же какой фирме-производителю отдать предпочтение?
и ещё вопрос: правди ли натяжитель перед установкой нужно в ванночке с маслом держать, что-бы он маслом заполнился?
Отредактировано Alex_cat87 (2012-04-15 23:33:45)
Serg
зачем?  ты его собираеш на двигателе, в ванночке он будет разобранный
гидротолкатели клапанов надо в ванночке держать с маслом
Kramarenko
Цитата: Pilot88052 от 13 апреля 2012, 12:23:56НАТЯЖИТЕЛЬ ЗАРЯЖАЕМ СТРОГО НА БЛОКЕ ЦИЛИНДРОВ
"заряжать", т.е., ставить плунжер, надо исключительно в руках до первого деления, а вот длинную пружину вгонять уже на двигателе после выставленных и прикрученных механических элементов. В противном случае это большой риск, т.к. натяжитель не всегда разряжается(распорная пружина может не сработать) и, как итог, его нерабоспособность натянуть цепь с последующими вытекающими...
Anton77790
Цитата: Игорь1982 от 19 марта 2012, 17:30:58пункту
Автодок пишет мб А1120100167 успокоитель цепи
SWAG планка успокоителя 10090085
